Date/Time: Mon, 25 Nov 2024 10:59:56 +0000
[User Discussion] - placing a dot or arrow on price charts based on value charts study
View Count: 1580
[2014-01-31 04:01:14]
User70152 - Posts: 20
I am looking to place a dot or up arrow under the candle if value chart indicator dips below -4, and a down arrow or dot above the candle if it passes +4. Is it possible to color the candle too? Thanks
[2014-01-31 04:28:43]
This can be done by using the Color Bar Based On Alert Condition study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245
[2014-01-31 04:48:21]
Sawtooth - Posts: 4120
If you mean to color the Value Chart bar, or place an arrow on the Value Chart bar, you could also do either or both with the same spreadsheet study used to color the Value Chart bands.
[2014-01-31 11:19:01]
Tomgilb. I meant price chart.
