Date/Time: Sat, 08 Feb 2025 22:06:04 +0000
Slow SC when USDMNX (USD Mex Peso) chart is opened
View Count: 710
[2020-07-30 12:58:13] |
User14683 - Posts: 34 |
When I open a USDMXN Spot Forex chart, all my Sierra Charts become very slow and "un-smooth"). When I close it, everything back to normal. I previously downloaded the ASDMXN and this also happened, therefore closed it. I mistakenly did something wrong as all my other charts are fine. How do I delete those data files to reload again? I tried to "Delete and Download" as far back as possible, but no improvement. I do not want to delete all charts data, only USDMXN. Thanks |
[2020-07-30 19:10:32] |
What studies are on that chart? Most likely the problem is what is explained here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
