Date/Time: Fri, 04 Apr 2025 13:15:45 +0000
Visual Trade Log Journal
View Count: 2769
[2020-07-30 04:05:26] |
vish100 - Posts: 111 |
SC provides great log of all your trades in terms of exit/entry, efficiencies PnL etc. But does it also have the feature of capturing visual screenshots of the charts with your trade entry/exits on it apart from the metric above? thanks |
[2020-07-30 09:41:53] |
We do plan to add journaling capability but not visual of the chart itself. However, it is possible to replay live order fills now: Replaying Charts: Replaying Non-Simulated / Live Order Fills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-30 09:42:11
[2020-07-30 11:34:38] |
Thanks. Also is it possible to export the trade activity log into an excel or something? I can't find the feature.
[2020-07-30 19:08:45] |
There are two options, one to save to a text file and one to export. Refer to the information here: Trade Activity Log: Saving to a Text File and here: Trade Activity Log: Importing and Exporting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-31 09:02:52] |
Thanks. Also one last thing. Is it possible to generate a hyperlink for each trade/fill so that you don't need to replay it every time. So when you click on that link it not only shows you the trade but also a small clip to play it? thanks Vish |
[2020-07-31 18:55:53] |
Those items are not supported from within Sierra Chart. You would have to create that using outside tools.
[2022-12-31 22:25:05] |
User223498 - Posts: 10 |
Is the journal functionality going to be developed? The features mentioned here would be very useful to many users.
[2023-01-03 17:54:01] |
John - SC Support - Posts: 39150 |
Some day we hope to get to the journaling, but there are other priorities at the moment.
