Date/Time: Thu, 24 Sep 2026 17:57:41 +0000
[User Discussion] - Cumulative Delta - Price Changes Per Bar
View Count: 1408
| [2020-07-29 21:27:07] |
| jchriston - Posts: 6 |
Hello - is there any way to create a Cumulative Delta study that reflects price changes per bar instead of trades. Essentially a price change up would be 1 and a price change down would be -1 and it would track the cumulative sum of these over time (exactly like the other CD studies do). Thanks! http://www.sierrachart.com/image.php?Image=1596057869807.png |
| [2020-07-29 21:34:07] |
Sorry I neglected to address - the screenshot illustrates a price change per bar set at 1 which seems to track that information - it's more of just how you go about creating (or can SC create) a cumulative delta sum of this.
| [2020-07-30 02:55:06] |
| User90125 - Posts: 715 |
Try using the Cumulative Data - Up/Down Tick Volume study. |
| [2020-07-30 14:53:06] |
That's slightly different than what I'm asking for - as is the trades. Trades is number of trades and up/down tick volume is the delta of the up tick and down tick volumes. I just am looking for raw price change up and down data (which exists in the price change per bar chart). Seems it wouldn't be too hard to implement (just beyond my knowledge :D)
