Date/Time: Sat, 08 Feb 2025 21:42:41 +0000
re-connecting to a DTC server (Sierra Charts, DTCBridge, etc.)
View Count: 534
[2020-07-29 17:04:06]
User21320 - Posts: 12
Please advise on the proper DTC procedure of software re-connecting to a DTC server (Sierra Charts, DTCBridge, etc.) to cancel or modify(cancel/replace) any open orders received in response to the OPEN_ORDERS_REQUEST in the ORDER_UPDATE->OPEN_ORDERS_REQUEST_RESPONSE after a crash/lockup/power down.
Since re-running the software will constitute a new session and the previous "ServerOrderID" and "ClientOrderID" will not be known, I am assuming that the server will create a new "ServerOrderID" to be used. However, in your DTC specs it states -
"The ClientOrderID is the order identifier provided by the Client.
When the Client submits a new order, cancels and replaces an existing order, or cancels an order,
then the Client needs to specify this identifier.
The Client must maintain the same order identifier throughout the life of the order.
The Server should persist the ClientOrderID across sessions.
A session is defined as the period of time from the start of the network connection between
the Client and Server to the end of that connection.
The Client should only rely upon the ClientOrderID being set when the OrderUpdateReason is one of the following:
NEW_ORDER_ACCEPTED, NEW_ORDER_REJECTED, ORDER_CANCELED, ORDER_CANCEL_REPLACE_COMPLETE, ORDER_CANCEL_REJECTED, ORDER_CANCEL_REPLACE_REJECTED.
After a new order has been accepted, the Client will rely upon the given ServerOrderID from the server to
identify the order and should no longer rely upon the given ClientOrderID. However, the Client needs to
maintain a copy of the ClientOrderID for any subsequent order modifications and cancellations because
this is a required field for those."
If the previous "ClientOrderID" is not known, should I send a new "ClientOrderID" in the message
to cancel or modify(cancel/replace) the open order(s) after the reconnect, or does the server also send me a new "ClientOrderID" upon re-connect to use for that purpose in response to the OPEN_ORDERS_REQUEST request ?
[2020-07-30 19:35:29]
No, definitely this identifier will remain the same.
You will know what it is when you receive the open orders with an open orders request.
