Date/Time: Sat, 08 Feb 2025 22:13:26 +0000
replay chart
View Count: 852
[2020-07-29 16:02:18] |
User548073 - Posts: 3 |
hey, when i use the replay chart. every chart in my chartbook set to another time they did not move together. you can help me to solve that?
[2020-07-29 19:49:54] |
Make sure that you select the option for All Charts in Chartbook for the Charts to Replay section. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ChartsToReplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-30 06:33:28] |
in my chartbook the grafh work ,but the foot print chart and the heat map dont work when i use the replay chart. all the settings ok.
[2020-07-30 20:51:15] |
What do you mean by 'foot print chart and the heat map dont work '? Are they not replaying or are they not displaying any data during the replay? Or are they not displaying what you are expecting them to show? Also, be sure you are aware of the following information with regards to the Market Depth Historical Graph (Heat Map) with regards to replays: Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-30 20:51:57
