Date/Time: Sat, 03 Oct 2026 22:44:53 +0000
Denali/Level 1 data...
View Count: 1596
[2020-07-29 14:38:35]
User629089 - Posts: 93
I'm still using Rithmic as my data feed and am looking to switch to Denali for SC's. I have the JS platform and will keep Rithmic for it. To potentially reduce costs I'm wondering if I could use Level 1 data for SC's with Denali and still get a footprint chart that looks like this below, or would I need Level 2 for that?
http://www.sierrachart.com/image.php?Image=1596033278651.png
Specifically I'm referring to the qty trading @ each price on the main chart along with the stats below and not the Market Data column in the right margin.
Thanks...
[2020-07-29 19:25:57]
John - SC Support - Posts: 48095
You do not need the Market Depth for any of the information that is displayed in that chart (apart from the Market Depth itself on the right, as you already noted). Therefore, just the Level 1 data would be sufficient, given what you have shown us.
[2020-07-31 16:45:16]
Thanks for the above info.
If using the Denali data feed with SC's with the order routing through SC's, does this combination provide server side order placement/holding? I'm sure you know but just in case you don't, for example, server side is if I have an order active and on my end the PC goes down, would my protective stop and limit order (a bracket/OCO bracket order type attached to my active order) still be active even when my PC is down?
Thanks...
[2020-07-31 20:01:57]
Yes, the Sierra Chart Order Routing Service supports Server Side Bracket and OCO orders. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#Included
