Date/Time: Sat, 08 Feb 2025 22:07:18 +0000
Is it possible for the SUM function to not add data from the previous day?
View Count: 515
[2020-07-29 14:22:34]
User484096 - Posts: 19
[2020-07-29 14:53:44]
User90125 - Posts: 715
Look at the Cumulative Sum of Study and set Reset at Start of Trading Day to Yes.
[2020-07-29 19:48:55]
To do what you want, you would need to create a new column of data that displays the data if it is part of Today's trading day and would output a 0 otherwise. Refer to the IF statement for Spreadsheets here:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#IF_Function
And refer to the following for working with Dates and Time:
Spreadsheet Functions: Serial DateTime Values
Also post #2 is a good solution.
Date Time Of Last Edit: 2020-07-29 19:49:14
