Date/Time: Sat, 08 Feb 2025 22:25:49 +0000
SC Memory Consumption Version 2138
View Count: 536
[2020-07-29 13:30:38]
User41727 - Posts: 124
Does version 2138 still have debug symbols enabled like 2137? Because otherwise there seems to be a memory leak. I do have quite a number of charts open, but SC is usually below 2 GB. Except, that version went higher and higher over the course of the session to the point where it was up to 12.5 GB physical memory. Version 2141 does not seem to exhibit the same behaviour so far, though.
[2020-07-29 19:47:24]
Version 2137 did not use debugging symbols. It was not optimized and had stack related run time checks.
No version should have any memory leak and we do not observe this.
Date Time Of Last Edit: 2020-07-29 19:47:49
