Date/Time: Mon, 25 Nov 2024 11:43:06 +0000
Value On High and Value On Low Draw Styles do not ignore zero
View Count: 1472
[2014-01-31 01:28:13] |
Sawtooth - Posts: 4120 |
I'm trying to use the Value On High and Value On Low Draw Styles in a spreadsheet study, but it seems they also use zero values, even though only numbers >0 are drawn. The zero values cause the price chart to compress.
[2014-02-04 16:43:24] |
We will be testing this today.
[2014-02-06 21:35:31] |
These Draw Styles will place the cell value in the correct places, but if the value is not commensurate with the price, the price graph is compressed. I'm expecting these Draw Styles to place the cell value On High and On Low as text, not as an actual value. If these cannot be made to do that, maybe you could add Text On High and Text On Low draw styles. Here is my original request for these draw styles: http://www.sierrachart.com/supportboard/showthread.php?t=41879 Date Time Of Last Edit: 2014-02-06 21:49:31
[2014-02-06 23:49:20] |
OK we got it. So these need to be excluded from scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-06 23:59:17] |
This will be solved in version 1090.
