Date/Time: Sat, 08 Feb 2025 22:22:46 +0000
Market Depth Historical Graph Bug
View Count: 634
[2020-07-29 01:32:14]
gr93 - Posts: 18
There are 2 ask levels here with size around 300, but one is colored lightly and the other is not. My thresholds are 100, 200, 300.
http://www.sierrachart.com/image.php?Image=1595986257346.png
EDIT: Since using the upload main chart window didn't work, here's a mirror. The 346 is colored lightly toward the bottom but the 303 toward the top is colored nearly the same as the 80 right below it. Also the 103s above and below the 303 are both dark compared to the 80. Not sure what's going on.
https://cdn.discordapp.com/attachments/487939735184998402/737847280115253299/unknown.png
Date Time Of Last Edit: 2020-07-29 01:44:26
