Date/Time: Sat, 08 Feb 2025 21:51:54 +0000
Add VbP to additional symbol
View Count: 668
[2020-07-28 21:45:15] |
User594974 - Posts: 34 |
Hi, I'd like to add volume profile to additional symbol below main price graph. For example, I have _ES_f as my main price graph then I add NQ_f below it as an additional symbol...I have multiple volume profiles for ES and I'd like the same profiles for NQ. It works perfectly on main price graph, but when I add it to an additional symbol, it remains blank. Any suggestions on how to fix this? Thank you.
[2020-07-30 19:39:27] |
This is not supported.
