Date/Time: Mon, 25 Nov 2024 10:44:46 +0000
Best Sierra Chart package for Using TD Ameritrade data
View Count: 1089
[2014-01-30 23:40:29] |
lou_diamonds - Posts: 39 |
If I want to use TD Ameritrade's data, which Sierra chart package will work with it? Will package 2 work for that? Thanks! |
[2014-01-31 01:07:46] |
No. You will need Sierra Chart package 1, 3 or 5.
