Date/Time: Fri, 07 Feb 2025 14:39:45 +0000
[User Discussion] - If, AND, OR - study with any combination of the above.
View Count: 837
[2020-07-28 16:54:17] |
User870514 - Posts: 25 |
Is there a pre-existing study (native or user-contributed) that can be chained, that is configured to take its input from the preceding study, check the value in relation to a further study and provide an output to the next study in the chain, i.e. perform an operation depending on the result? Effectively an If This Then That decision tree which can undertake this operation in IF, AND, OR format with multiple conditions or rules. Suggestions will be appreciated. |
[2020-07-29 15:17:18] |
ForgivingComputers.com - Posts: 995 |
I don't know of any existing studies, but it seems doable. I sent you a direct message request. Brad Houser ForgivingComputers.com |
[2020-07-30 11:21:33] |
binaryduke - Posts: 377 |
Use Color Bar Based on Alert Condition. Evaluate the 'previous' study based on your conditions and you have something that will evaluate to 1 (true) or 0 (false). You can then get creative with additional instances of Color Bar Based on Alert Condition that evaluate this 1/0 condition; Arithmetic studies (e.g. Study Subgraphs Multiply), etc, etc.
[2020-07-30 11:31:10] |
Yeah, I have that delivering part of the required setup but am considering more complicated arrangements. I am trying to understand the conditional arguments that can be used in the alert condition filed and whether it can deal with multiple references to other studies such as coloraturas bar slope or cooler bar above below etc.
Date Time Of Last Edit: 2020-08-04 11:40:21
