Date/Time: Sat, 08 Feb 2025 21:43:07 +0000
How to get Number Bar text on forefront of drawing lines
View Count: 543
[2020-07-28 15:49:49] |
Profile Trader - Posts: 177 |
Looking for a way to make Number Bar text the forefront of any drawing line. I have looked in NB study and also properties of drawing line and don't see anything. I'm sure it is possible what am I missing? Thanks, Doug |
[2020-07-29 05:11:51] |
Refer to the information here: Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
