Date/Time: Sat, 08 Feb 2025 22:25:25 +0000
Denali live data with compatible brokers
View Count: 669
[2020-07-27 20:19:41] |
Rodger - Posts: 2 |
Hi, if I use Denali live data, which brokers are recommended to be compatible with Sierra Chart?
[2020-07-28 22:03:45] |
The answer to the question you are asking is found on this page: Supported Data and Trading Services But, we think you are really asking about the Sierra Chart Order Routing service. In which case, refer to the information in Step #2 of the Setup Instructions here: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
