Date/Time: Mon, 21 Sep 2026 22:49:08 +0000
ACSIL sc.GetOrderFillEntry() TradePositionQuantity error when position quantity is negativ
View Count: 914
[2020-07-27 07:44:00]
CMG - Posts: 179
Hi There,
1. Im using function sc.GetOrderFillEntry() to output trade data to spreadsheets. However, member variable TradePositionQuantity returns the correct quantity only when net position is positive. Whenever the position quantity is negative, irrelevant of the size, "-2147483647" is returned.
Im using the following code taken from one of the examples, not sure if the problem is here:
sc.GetOrderFillEntry(CurrentOrderFillEntrySize -1, OrderFillData);
uint32_t OrderQuantity = static_cast<uint32_t>(OrderFillData.Quantity);
  uint32_t InternalOrderID = static_cast<uint32_t>(OrderFillData.InternalOrderID);
  uint32_t TradePositionQuantity = static_cast<uint32_t>(OrderFillData.TradePositionQuantity);
2. I noticed that after upgrade to SC 2138, the Spreadsheet>NUMBER FORMAT>Default is changing CUSTOM CELL BACKGROUND COLORS to to the default white.
[2020-07-27 19:03:44]
1. We do not see any problem with this. The issue might have to do with the fact that you are putting the quantity into an unsigned integer when it needs to be signed.
2. We will look into this.
Date Time Of Last Edit: 2020-07-27 19:03:52
