Date/Time: Mon, 25 Nov 2024 10:29:09 +0000
[User Discussion] - a way to have the midpoint of each candlestick bar drawn?
View Count: 2238
[2014-01-30 19:42:26] |
Seanz - Posts: 17 |
I'd like to be able to see the midpoint of each individual candle - is there an easy way to do this? thanks, Sean |
[2014-01-30 23:46:00] |
User59135 - Posts: 15 |
You can add the Auto Retracement/projection study for this. In the settings tab, select the chart periodicity you are using and make any level "0.5". This will draw the middle of all candlesticks/bars/whatever.
[2014-01-31 01:21:09] |
Seanz - Posts: 17 |
thanks, really appreciate your help - it would never have occurred to me to use that study.
