Date/Time: Tue, 22 Sep 2026 09:09:58 +0000
New Version..
View Count: 823
[2020-07-26 23:47:27]
User750920 - Posts: 297
I just downloaded the new version. Two questions.
When I set the settings for a study there used to be a box to check to make it the default setting so if I added it to another chart I did not have to re-set all the settings again. This is cumbersome with the TPO profile Study. Is the replacement the Set Defaults button just to the left of the Reset Defaults button?
And the other questions is for example when I have 2 charts in a window and one of the charts is behind the other as I do not use it often when I save the chartbook the chart I want to be the forefront chart gets put behind the one I do not every time I go to another chartbook and then return to the original chartbook. I have tried putting it in front and re-saving it but it does not work and just reverts back. Any way to fix this so the chartbook layout stays exactly as I save it.
[2020-07-28 18:34:40]
1. Refer to the updated documentation here regarding default study settings:
Chart Studies: Using Custom Default Study Settings
2. This is controllable through this settings window:
Window, CB and CW Menus: Windows and Chartbooks (Window)
