Date/Time: Sun, 09 Feb 2025 03:22:41 +0000
VBP location on the time scale
View Count: 557
[2020-07-25 21:27:36]
QnReally - Posts: 181
For VBPs that are drawn on the chart bars I can know at chart index the VBP graphic begins or ends (it is the first or the last index of the bars covered by the VBP depending on the left/right aligned VBP). I am trying to draw text labels for the VBP graphics. This works for the above scenario. However, when I have several VBPs all aligned to far right I can't tell at what chart index they end for me to line up the labels (for peaks/valleys). As I scroll the chart up/down on the price scale, the labels stay static while VBPs move left/right depending on the what VBPs go in and out of view. I would appreciate a way to access the bar index at which the VBP ends for the right aligned VBPs via ACSIL. Is it possible to support this please?
Thanks.
Please see the attached image: http://www.sierrachart.com/image.php?Image=1595713043791.png
Date Time Of Last Edit: 2020-07-25 21:37:55
image2020-07-25_17-20-20.png / V - Attached On 2020-07-25 21:24:03 UTC - Size: 168.85 KB - 238 views
[2020-08-06 13:08:33]
Any possibility for this? Thanks.
