Date/Time: Sat, 08 Feb 2025 21:22:49 +0000
Problem wihth Rythmics
View Count: 575
[2020-07-24 16:03:30]
Xtremtrade - Posts: 2
Hi
I have a big problem about synhronization Show fills trading, you can check wich is the problem thanks ?!!
[2020-07-24 19:11:48]
Refer to this section:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities
You should also really use the Sierra Chart Order Routing Service to have complete fill history with each fill having a Position Quantity:
Sierra Chart / Trading Technologies Futures Order Routing Service
More information:
Help With Daily Profit/Loss Value: Consistently Accurate Daily Profit/Loss Value
Date Time Of Last Edit: 2020-07-24 19:13:38
[2020-07-27 07:53:17]
Hi ! I know very well Sierra chart ! but problem is not this !!!!
imageAnnotation 2020-07-27 095215.png / V - Attached On 2020-07-27 07:52:24 UTC - Size: 20.36 KB - 226 views
[2020-07-27 19:28:53]
We do not understand what you are trying to show us.
