Date/Time: Sat, 08 Feb 2025 19:08:00 +0000
[Programming Help] - Programmatically getting TPO values to plot in OHLC bar chart
View Count: 552
[2020-07-24 15:06:50]
User641030 - Posts: 13
I would like to get TPO study data (like PoC, Value Area High/Low) from a TPO chart and use it in a OHLC bar chart. Something like the sc.GetStudyProfileInformation from chart using ID.
I tried using the GetStudyArraysFromChartUsingID, but I'm unable to use data. Ideally if I can access the n_ACSIL::s_StudyProfileInformation from a bar chart, it will be great. Is it doable? If not, is there a workaround? Thanks in advance.
Thank you
HN
