Date/Time: Fri, 07 Feb 2025 15:09:13 +0000
Color Bar Based on Alert Condition
View Count: 579
[2020-07-24 14:25:44] |
User837393 - Posts: 135 |
Hello I'm currently using the Color Bar Based On Alert Condtion, but it only colors the body of the candle, the candle frame remains the same. What should I look for if I want to have the entire candle to be colored. Right now in the subgraph seting I have it set to Draw style is : Color Bar. Best regards. |
[2020-07-24 15:30:13] |
John - SC Support - Posts: 37808 |
Please attach a screenshot so we can see what is happening. Refer to the information here for how to take a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
