Date/Time: Sat, 08 Feb 2025 18:41:03 +0000
Sierra chart order routing service
View Count: 510
[2020-07-24 10:17:40] |
vish100 - Posts: 111 |
Hi, I am currently using SC --> CQG --> AMP for trading CME futures like Emini, SPI200 etc. I want to switch to Sierra chart order routing service. I am in Australia. Is it possible? thanks Vish |
[2020-07-24 19:07:12] |
The Sierra Chart data feeds do not yet support real-time data for the Australia exchange. So you really cannot use the Sierra Chart order routing service at this time. Check back in a few months.
