Date/Time: Sat, 08 Feb 2025 21:27:46 +0000
disble copy of specific
View Count: 656
[2020-07-24 06:08:35] |
yp1959 - Posts: 3 |
As you know for sure, there is an option to make a chart copy draws from other charts (call them target charts) by indicating their chart ID However, there are draws that I don't want to be copied from the target chart to the chart that chart that asks to copy the draws. So my idea is to add an option to each draw (on the target chart) where I can choose to disable its copying when a chart is asking a copy of all draws of a target chart, only figures that are not disabled for-copy will be copied The current situation creates many times a mess which my proposal will avoid. |
[2020-07-24 06:49:31] |
User907968 - Posts: 826 |
Chart Settings: Excluding Specific Chart Drawings from Being Copied
[2020-07-24 09:23:57] |
This is better documentation on this subject: Copying Chart Drawings from Other Charts Automatically: Preventing Specific Chart Drawings from Being Copied Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-24 23:55:08] |
yp1959 - Posts: 3 |
Sorry, I don't have (on the context menu of the drawing) the option that is mentioned in the documentation What should I do? |
[2020-07-25 02:21:58] |
You need to add that to the menu: Chart Drawing Tools: Customizing Chart Drawing Shortcut Menu You also need to update to the current version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-25 08:15:52] |
yp1959 - Posts: 3 |
would it be possible calling the menu-customization from the drawing context-menu?
[2020-07-27 18:50:27] |
We will look into this.
[2020-07-27 18:55:30] |
This is already supported. Refer to: Global Settings Menu: Customize Menu Items (Global Settings menu) And refer to: Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
