Date/Time: Mon, 25 Nov 2024 10:22:13 +0000
Increasing the spacing between a chart and the "right edge".
View Count: 1735
[2014-01-30 18:34:38]
User71822 - Posts: 24
The default setting on Sierra Chart, when opening a new chart, is to plot the current bar immediately to the left of the price scale at the right side of the chart. I would like to position the current bar so that it will maintain 4 or 5 bars of space between the "current bar" and the right side of the chart. Is there a way to do that? Thanks for your help.
[2014-01-31 04:34:42]
Yes. Once you have set up an existing chart with the fill space as you require and have locked it:
http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ScrollingTheChart
Then you will want to duplicate a chart as explained here:
https://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#DuplicateChart
