Date/Time: Mon, 25 Nov 2024 16:42:20 +0000
Having 3 Chartbooks open for viewing at same time.
View Count: 1264
[2014-01-30 18:30:09] |
User22591 - Posts: 133 |
How do I go about having the 3 chartbooks fully open together. I have tried to di this however when I go from one to the other the previous one is remove from the screen. I would like to do this on Split screen if possible or on three different screens. Thanks Date Time Of Last Edit: 2014-01-30 18:32:06
[2014-01-30 18:31:52] |
This is not supported. Only one can be visible at a time.
[2014-01-30 19:01:14] |
ejtrader - Posts: 688 |
User22591 - One of the solutions I think of - have 3 installs of SC - and just use remote data from primary instance. This would allow you to have 3 chart books for visibility.
[2014-02-20 17:35:47] |
Futures Operator - Posts: 239 |
Could it be possible to add support for this feature? Would be very useful to organize charts in different chartbooks, and move them between screens together as one grid, rather than tediously one by one.
[2014-02-20 19:13:56] |
User025822 - Posts: 35 |
+1
[2014-02-20 19:25:36] |
Auspicatum - Posts: 46 |
Are you telling me there is no way to run multiple monitors ?
Date Time Of Last Edit: 2014-02-20 19:25:58
[2014-02-20 19:49:29] |
ganz - Posts: 1048 |
Auspicatum Chart --> Detach/Attach Chart Window Window --> Chart Window Always Visible |
[2014-02-24 05:38:41] |
thank you ganz. |
[2014-02-24 08:00:15] |
See: https://www.sierrachart.com/index.php?l=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
