Date/Time: Sat, 08 Feb 2025 18:51:08 +0000
Market depth history study
View Count: 462
[2020-07-23 22:28:39] |
User671188 - Posts: 5 |
Hi support, Is it possible to check out the study Market depth history before I upgrade to service package 5? Or do I need to upgrade first to see it work? Kind regards Peter |
[2020-07-24 14:33:35] |
John - SC Support - Posts: 37842 |
Your account has been setup to evaluate Package 5 until August 22, 2020. You now have access to the full functionality of Sierra Chart until that time. If you have not already done so, it is best that you exit Sierra Chart and then login again to ensure that your system receives the updated information. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
