Date/Time: Sat, 08 Feb 2025 19:19:15 +0000
Losing brackets when order fills
View Count: 529
[2020-07-23 17:35:11] |
User186655 - Posts: 2 |
I enter a limit order with a simple bracket, stop and target. When order fills, the target and stop disappear and the order is open with no stop protection. Then, if I try to set a stop on the order, it automatically closes the position
[2020-07-23 19:02:49] |
It sounds like the Child/Attached Orders are getting rejected. Check the Trade Activity Log for the reason: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
