Date/Time: Sat, 08 Feb 2025 19:07:33 +0000
Gain Capital data connection using Zaner as introducing broker
View Count: 556
[2020-07-23 16:51:07] |
User143710 - Posts: 2 |
I have a Gain Capital account via Zaner as the introducing broker. The SC connection instructions advise that I should contact support as Zaner is not on the list of specified brokers. Kindly advise how I can connect to this live data source from a live account. Thank you. |
[2020-07-23 19:24:31] |
Gain Capital is supported. It is considered one of the legacy services. You would configure Sierra Chart for that service through Global Settings >> Data/Trade Service Settings >> Service. It is listed as Gain Capital.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-23 19:24:48
