Date/Time: Mon, 25 Nov 2024 09:41:47 +0000
STOP ORDERS
View Count: 977
[2014-01-30 17:54:05] |
User82615 - Posts: 106 |
Hello I have a problem : when I program an stop order in a system , if not touched this order is cancelled the next bar of when the stop order was sent . How can I prevent the stop order from getting cancelled? Thank you very much |
[2014-01-30 18:14:18] |
It would only be canceled if your trading system is canceling it. There are automated trading management settings which could cause an order to be canceled and they are documented here: http://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
