Date/Time: Sat, 08 Feb 2025 19:12:39 +0000
funded account
View Count: 519
[2020-07-23 15:16:03] |
User743539 - Posts: 3 |
Greetings, I am currently using Sierra Package # 3 with AMP, I am about to apply to a funded account and I want to know if I can continue using the same credentials
[2020-07-23 20:36:18] |
You can continue to use the same credentials, but you will have to let AMP know that this is what you want to do.
