Date/Time: Sat, 08 Feb 2025 19:24:34 +0000
Sierra DOM freeze and delay
View Count: 573
[2020-07-23 14:51:05] |
User652974 - Posts: 3 |
Hi, Today(23th July) I was experiencing severe delay and freezing on the sierra chart dom for the ES futures, I use the sierra charts provided datafeed by TT fix. Can you please help and let me know what happened today? I've checked and it was not my internet. Thanks |
[2020-07-23 15:55:18] |
John - SC Support - Posts: 37842 |
We are not seeing any issues currently. Let us know if you are still having issues at the moment. Additionally, please attach your Message Log so we can see if there was anything showing in there that might explain a problem getting the data. Please let us know about what time you were seeing the problems and what time zone you are in. Refer to the information here for how to attach your Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-23 16:07:13] |
Apologies John, it seems like it was in fact my internet. I initially did a test by using other apps and viewing the speed, it seemed okay. Afterward it did get worse and I can relay this back to internet issues. Thanks |
[2020-07-23 19:11:00] |
No this is not true. Sierra Chart does not support any TT data feed. We do support TT for order routing.Also refer to: Prices / Data Falling Behind: 4.16 - Monitoring Sierra Chart Data Feed Performance from Perspective of Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
