Date/Time: Sat, 08 Feb 2025 18:50:25 +0000
Just got set up with Amp trading, got credentials and logged in then
View Count: 525
[2020-07-23 14:47:48] |
User186655 - Posts: 2 |
I had to disconnect and reset my connection, now I cant get SC to log in.Is the service setting for supposed to be cqg Web? or something else?
[2020-07-23 20:01:43] |
It depends on what service AMP has you setup to use. If you are meant to use CQG, then following the instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
