Date/Time: Mon, 25 Nov 2024 09:55:31 +0000
Cumulative Sum Of Ask Volume Bid Volume Total
View Count: 1591
[2014-01-30 17:39:51] |
joeroma - Posts: 43 |
In the Number Bars Calculated Values study I noted that the Subgraphs AskVolBidVolTotal (SG2) and Total Vol (SG13) give the identical number so I don't know what the difference between these 2 is supposed to be. I noticed this while looking for a Subgraph that would give the cumulative total of the volume for each day but I didn't see one. I know you guys are busy but since you already have the subgraph Cumulative Sum of Ask Volume Bid Volume Difference - Day (SG10) which resets at the start of each trading day, is it possible to add an identical subgraph but with the cumulative Total of the BidV and AskV rather than their cumulative Difference. If you can do this it would be greatly appreciated. Thanks.
[2014-01-30 18:16:22] |
Effectively there is no difference between them. We will see about adding the other requested Subgraph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
