Date/Time: Sat, 08 Feb 2025 18:47:50 +0000
[Programming Help] - Study to show MAX-line of e.g. Volume Bars in specific time span
View Count: 613
[2020-07-22 21:59:30] |
Stephan_CH - Posts: 18 |
Hi I'm looking and trying for many hours how.. In a normal daily (historical) chart, I have a study "Volume". Now I'm looking for a study which shows me vor the last e.g. 90 Days a Maximum-Line on the level of the highes Volume Bar. If maybe today we have the highes volume of the last 90 days, then the line goes higher and hold this level as long as higher Volume day comes within the 90 days span. I have really no idea where I have to search for it. Have tried dozens of studies with span/range/ etc. Would be very happy for a hint. Thanks a lot and kind regards, Stephan |
![]() Attachment Deleted. |
[2020-07-23 05:31:50] |
You need to use this study: Highest High/Lowest Low Over N Bars And base it on the Volume study. The documentation explains how to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
