Date/Time: Sun, 20 Sep 2026 14:56:30 +0000
Sierra Futures
View Count: 5475
| [2020-07-22 19:31:44] |
| jbetlach - Posts: 30 |
Is this broker associated with Sierrachart? https://sierrafutures.stage5trading.com/ Date Time Of Last Edit: 2020-07-22 21:31:36
| [2020-07-22 22:19:44] |
| AD544 - Posts: 64 |
It looks like INFINITY FUTURES the owner Antony Giacomin is a NFA associate member of Infinity Futures https://www.nfa.futures.org/BasicNet/basic-profile.aspx?nfaid=YQOm4nUprdo%3D https://www.nfa.futures.org/BasicNet/basic-profile.aspx?nfaid=p8qZyZMeDSc%3D Date Time Of Last Edit: 2020-07-22 22:19:59
| [2020-07-22 23:15:31] |
| User75002 - Posts: 117 |
It is Stage 5 Trading, not Infinity Futures.
| [2020-07-23 06:01:57] |
It certainly looks like Stage 5 considering the domain name. On the other side they write in their FAQ, that they clear via Advantage Future. Which I believe Stage 5 does not. My question was, whether the Sierra Futures is anyhow associated or directly supported by Sierrachart. Not only because of the name, but mainly because they use SC order routing and Denali feed. Date Time Of Last Edit: 2020-07-23 06:04:27
| [2020-07-23 06:28:45] |
That broker is not affiliated with Sierra Chart in the sense that we are not in the brokerage business. They certainly offer Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-23 06:29:11
| [2020-07-23 07:08:06] |
Do they enjoy the same kind of support for SC order routing like AMP does?
| [2020-07-23 07:46:35] |
Yes they do support the Sierra Chart order routing service if that is the question.
| [2020-07-23 07:59:23] |
Yes, kind of. I am considering which broker / FCM I will choose for futures trading using SC and Sierrachart order routing / Denali datafeed. My preference is for a broker, which is fully supported by Sierrachart.
| [2020-07-23 10:06:03] |
I just got an offer from Stage 5. It is correct that they use Advantage Futures as an FCM for this. Everything can be billed from the brokerage account (Sierrachart, Denali datafeed and the order routing). It makes it quite an attractive option, comparable to AMP. |
| [2020-07-23 19:35:43] |
| AD544 - Posts: 64 |
Comparable to AMP? 55 cents per side + fees also for emicros? |
| [2020-07-25 10:43:38] |
These 55 cents alreday include 10 cents for SC order routing. Does AMP offer less than 45 cents then?
Date Time Of Last Edit: 2020-07-25 10:44:01
| [2020-07-26 16:19:28] |
| AD544 - Posts: 64 |
AMP offers 0.39 per side all in. (CQG all cost included) 0.37 if you have more than 10k of balance They do not charge any commission on emicros Their gain comes from clearing Nobody can beat them 0.74 round trip all in for 1 micros https://portal.ampclearing.com/account/commissionquote.aspx Date Time Of Last Edit: 2020-07-26 16:25:01
| [2020-12-29 18:45:19] |
| User676707 - Posts: 13 |
But they are cheaper for e-minis.
