Date/Time: Sat, 08 Feb 2025 19:21:26 +0000
EUREX feed
View Count: 512
[2020-07-22 18:01:25] |
arruga - Posts: 253 |
Could you explain how to fix this? http://www.sierrachart.com/image.php?Image=1595440762824.png Had the same issue in GBL (bund), but delete/download fixed it... but DAX not fixed with that |
[2020-07-23 05:15:19] |
You are using Interactive Brokers data which we do not provide support for. We recommend activating the EUREX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures And then after that is activated, then re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-23 05:15:37
