Date/Time: Mon, 25 Nov 2024 09:44:06 +0000
Is it possible to edit an .scid file?
View Count: 1180
[2014-01-30 17:27:08] |
trader1 - Posts: 128 |
Just wondering how to do this to quickly correct multiple data feed errors. I would like to edit it directly rather than use edit/download data intraday chart. Thanks. |
[2014-01-30 18:17:22] |
Yes. Refer to these pages: http://www.sierrachart.com/index.php?l=doc/doc_IntradayDataEditor.html http://www.sierrachart.com/index.php?l=doc/doc_IntradayDataFileFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
