Date/Time: Fri, 25 Sep 2026 20:12:39 +0000
Rithmic setup
View Count: 1034
[2020-07-22 16:50:54]
User229298 - Posts: 1
I already have an active Sierra Charts package and trade actively through Amp Clearing. I downloaded another instance of Sierra to another drive on my computer and I am trying to use it to connect also to Earn2Trade via Rithmic. I used my Sierra login on the startup and then setup the data feed as Rithmic and then Rithmic Paper Trading, as Earn2Trade said in their instructions. I used my Rithmic username and password and it keeps giving me an error message. I know this info is correct because I used it to log into the Rithmic site to sign the data agreements.
I am including the log if that helps below:
Software version: 2068 64-bit | 2020-07-22 11:46:51.346
Enabled for: Sierra Chart Historical Data Service. | 2020-07-22 11:46:51.346
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-07-22 11:46:51.346
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-07-22 11:46:51.346
Current selected Data/Trading service: Rithmic Trading | 2020-07-22 11:46:51.346
Custom symbol settings values: enabled | 2020-07-22 11:46:51.346
Chart Update Interval: 500 | 2020-07-22 11:46:51.346
Intraday Data Storage Time Unit: 1 | 2020-07-22 11:46:51.346
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-07-22 11:46:51.346
2020-07-22 11:46:51 Local computer time | 2020-07-22 11:46:51.346
2020-07-22 15:46:51 Local computer time in UTC | 2020-07-22 11:46:51.346
2020-07-22 11:46:51 Local computer time in SC Time Zone | 2020-07-22 11:46:51.346
2020-07-22 15:41:50 Server time in UTC | 2020-07-22 11:46:51.346
Local computer UTC time and Server UTC time difference: 3 seconds. | 2020-07-22 11:46:51.346
Program path: C:\SierraChart2\ | 2020-07-22 11:46:51.346
Data Files path: C:\SierraChart2\Data\ | 2020-07-22 11:46:51.346
OS Version Number: 6.3 | 2020-07-22 11:46:51.346
Locale Setting: C | 2020-07-22 11:46:51.346
DLLs: UserContributedStudies_64.dll | 2020-07-22 11:46:51.346
Rithmic Trading | Port for executable: 58977 | 2020-07-22 11:47:00.691
Listening socket (1284). Port 58977 | Closed. | 2020-07-22 11:47:00.692
Rithmic Trading | Starting server: C:\SierraChart2\Rim\DTCBridge.exe | 2020-07-22 11:47:00.692
Created process C:\SierraChart2\Rim\DTCBridge.exe. Parameters: /Port:58977. Current folder: C:\SierraChart2\Rim | 2020-07-22 11:47:00.704
Rithmic Trading | Bridge process is running. | 2020-07-22 11:47:02.694
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58977 | 2020-07-22 11:47:02.694
DTC Client socket (1) | Creating socket. | 2020-07-22 11:47:02.694
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-07-22 11:47:02.694
Rithmic Trading | Connected to server. | 2020-07-22 11:47:02.695
Rithmic Trading | Starting socket receive thread. | 2020-07-22 11:47:02.695
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-07-22 11:47:02.695
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-07-22 11:47:02.697
Rithmic Trading | Sending logon request message. | 2020-07-22 11:47:02.697
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-07-22 11:47:02.699
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart2\Rim\Rithmic.log | 2020-07-22 11:47:02.704
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-07-22 11:47:02.704
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-07-22 11:47:03.116
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-07-22 11:47:03.316
Rithmic Trading | Received logon response. | 2020-07-22 11:47:03.316
Rithmic Trading | Server Name: DTC Bridge. | 2020-07-22 11:47:03.316
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-07-22 11:47:03.316
Rithmic Trading | Logon error received from server | 2020-07-22 11:47:03.316
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-07-22 11:47:03.316
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-07-22 11:47:03.316
DTC Client socket (1) | CloseSocket call. | 2020-07-22 11:47:03.368
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-07-22 11:47:03.368
Rithmic Trading | Disconnected. | 2020-07-22 11:47:03.368
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-07-22 11:47:05.808 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-07-22 11:47:05.808
DTC Client socket (1) | Closed. | 2020-07-22 11:47:05.808
Rithmic Trading | Port for executable: 55859 | 2020-07-22 12:15:09.138
Listening socket (1344). Port 55859 | Closed. | 2020-07-22 12:15:09.138
Rithmic Trading | Starting server: C:\SierraChart2\Rim\DTCBridge.exe | 2020-07-22 12:15:09.138
Created process C:\SierraChart2\Rim\DTCBridge.exe. Parameters: /Port:55859. Current folder: C:\SierraChart2\Rim | 2020-07-22 12:15:09.151
Rithmic Trading | Bridge process is running. | 2020-07-22 12:15:11.146
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55859 | 2020-07-22 12:15:11.146
DTC Client socket (1) | Creating socket. | 2020-07-22 12:15:11.146
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-07-22 12:15:11.146
Rithmic Trading | Connected to server. | 2020-07-22 12:15:11.148
Rithmic Trading | Starting socket receive thread. | 2020-07-22 12:15:11.148
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-07-22 12:15:11.148
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-07-22 12:15:11.152
Rithmic Trading | Sending logon request message. | 2020-07-22 12:15:11.152
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-07-22 12:15:11.155
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart2\Rim\Rithmic.log | 2020-07-22 12:15:11.158
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-07-22 12:15:11.158
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-07-22 12:15:11.663
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-07-22 12:15:11.876
Rithmic Trading | Received logon response. | 2020-07-22 12:15:11.876
Rithmic Trading | Server Name: DTC Bridge. | 2020-07-22 12:15:11.876
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-07-22 12:15:11.876
Rithmic Trading | Logon error received from server | 2020-07-22 12:15:11.876
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-07-22 12:15:11.876
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-07-22 12:15:11.876
DTC Client socket (1) | CloseSocket call. | 2020-07-22 12:15:11.924
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-07-22 12:15:11.924
Rithmic Trading | Disconnected. | 2020-07-22 12:15:11.925
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-07-22 12:15:14.282 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-07-22 12:15:14.282
DTC Client socket (1) | Closed. | 2020-07-22 12:15:14.282
Rithmic Trading | Port for executable: 55913 | 2020-07-22 12:15:39.327
Listening socket (1220). Port 55913 | Closed. | 2020-07-22 12:15:39.327
Rithmic Trading | Starting server: C:\SierraChart2\Rim\DTCBridge.exe | 2020-07-22 12:15:39.327
Created process C:\SierraChart2\Rim\DTCBridge.exe. Parameters: /Port:55913. Current folder: C:\SierraChart2\Rim | 2020-07-22 12:15:39.346
Rithmic Trading | Bridge process is running. | 2020-07-22 12:15:41.333
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55913 | 2020-07-22 12:15:41.333
DTC Client socket (1) | Creating socket. | 2020-07-22 12:15:41.333
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-07-22 12:15:41.333
Rithmic Trading | Connected to server. | 2020-07-22 12:15:41.334
Rithmic Trading | Starting socket receive thread. | 2020-07-22 12:15:41.334
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-07-22 12:15:41.334
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-07-22 12:15:41.336
Rithmic Trading | Sending logon request message. | 2020-07-22 12:15:41.336
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-07-22 12:15:41.338
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart2\Rim\Rithmic.log | 2020-07-22 12:15:41.340
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-07-22 12:15:41.340
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-07-22 12:15:41.773
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-07-22 12:15:41.989
Rithmic Trading | Received logon response. | 2020-07-22 12:15:41.990
Rithmic Trading | Server Name: DTC Bridge. | 2020-07-22 12:15:41.990
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-07-22 12:15:41.990
Rithmic Trading | Logon error received from server | 2020-07-22 12:15:41.990
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-07-22 12:15:41.990
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-07-22 12:15:41.990
DTC Client socket (1) | CloseSocket call. | 2020-07-22 12:15:42.037
Rithmic Trading | Disconnected. | 2020-07-22 12:15:42.037
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-07-22 12:15:42.038
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-07-22 12:15:44.428 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-07-22 12:15:44.428
DTC Client socket (1) | Closed. | 2020-07-22 12:15:44.428
