Date/Time: Mon, 25 Nov 2024 17:51:47 +0000
TRAILING STOP ORDER USING ACSIL
View Count: 1788
[2014-01-30 17:22:39]
User82615 - Posts: 106
Hello , Can anybody send me an example on how to program a trailing stop order using ACSIL please?
Thank you very much
[2014-01-30 19:08:00]
We will put together an example. Did you want the trailing stop order to be the main order or to use as an Attached order to a main/parent order?
[2014-02-25 01:19:38]
      // Trailing stop order. This has no Attached Orders.
      // The trailing offset is the difference between the current market price for the Symbol of the chart the trading study is applied to
      // and the price set by NewOrder.Price1
      // Create an s_SCNewOrder object.
      s_SCNewOrder NewOrder;
      NewOrder.OrderQuantity = 2;
      NewOrder.OrderType = SCT_ORDERTYPE_TRAILING_STOP;
      NewOrder.Price1 = sc.BaseData[SC_LAST][sc.Index] - 10*sc.TickSize;
      sc.SellOrder(NewOrder);
[2014-02-25 11:45:16]
THAK YOU VERY MUCH FOR YOUR HELP AND YOUR HARD WORK
