Date/Time: Thu, 21 Nov 2024 17:20:23 +0000
Feature Request - Mouse Click & Hold Functionality
View Count: 1622
[2020-07-22 13:27:03] |
osaga - Posts: 53 |
I have, what I believe is, a very useful and smart feature request. The Problem: I use the hand tool very frequently, as I'm sure do many other users, to move the chart around. The problem is I have to constantly switch back and forth between the hand tool and other tools I use, but the hand tool gets the most use. Solution: Right click and hold will activate the hand tool and will stay activated as long as the right button is held down. Then I can move the chart as needed. What I let go it returns to the previously active tool. This will not interfere with the simple right click to bring up the quick select order menu. Another option might be to allow the user to select a limited number of other tools that will temporary activate with the right click and hold option. Thank you SC team for your time and consideration of this. Regards Date Time Of Last Edit: 2020-07-22 15:08:34
[2020-07-22 15:50:16] |
User441146 - Posts: 8 |
+1 it would be amazing
[2020-07-22 15:59:15] |
User90125 - Posts: 715 |
Just go to Global Settings >> Tool Settings, and under the General tab use the dropdown called After Single Tool Use Change To, and set it to Hand.
[2020-07-22 16:04:33] |
osaga - Posts: 53 |
That kind of does what I'm asking, but not the full functionality I am requesting. What I'm requesting is a toggling behavior.
Date Time Of Last Edit: 2020-07-22 16:05:08
[2020-07-22 16:15:29] |
OK. There is also a setting on the same General tab which is a dropdown called Right Click Exits Current Drawing Tool To. Try setting that to Hand, or whatever will help give you the functionality you desire. |
[2020-07-22 16:23:36] |
osaga - Posts: 53 |
The functionality I am looking for is when the mouse button is held down. I appreciate the help and ideas. Thank you!
[2020-07-22 17:30:12] |
No prob. Hopefully SC Support will be along to help you out further.
[2020-07-23 05:32:42] |
Have a look at the settings here for the Chart Values tool : Chart Drawing Tools: Chart Values Tool Configuration Action When Other Tools Selected This may not be what you need though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-23 05:33:46
[2020-07-23 10:49:40] |
osaga - Posts: 53 |
This is definitely close to what I am requesting. Really just want the hand tool to activate (toggled on) when the right mouse button is held down. This way regardless of the tool selected I can always move the chart. I think having a configuration setting that says "When right mouse button held down the following tool will be active:"... and then a drop down list of the following tools would be available: - Hand - Chart Values Tool - Zoom In I understand you have priorities for features. Thanks for the consideration and time SC. Regards |
[2022-04-25 11:50:40] |
virtualcointrading - Posts: 39 |
Another way to implement this would be to have the crosshair on mouse over activated by default on charts and left/right click would activate the selected tool. It's the case on tradingview.
[2024-11-02 13:44:32] |
gaoxxxx - Posts: 2 |
change"action when other tools selected(list)" to "always on when using other tools"
