Date/Time: Mon, 25 Nov 2024 09:42:41 +0000
latency
View Count: 1085
[2014-01-30 16:46:25] |
User40526 - Posts: 166 |
I am running 2 copies of Sierra Chart on one computer and the second copy has latency. My data feed is from Interactive Brokers. My processor is AMD 4100 Quad Core, 3.6 GHz, 64 bit op system and 8 Gig Ram. Suggestions? Thanks
[2014-01-30 18:06:07] |
Refer to help topic 4 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails4.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
