Date/Time: Sat, 08 Feb 2025 18:47:21 +0000
Chart trading using data from one provder but clearing through another
View Count: 513
[2020-07-22 00:36:21] |
User629461 - Posts: 184 |
Hi, I want trade the Korean futures, however the only broker I have found that supports this contract is Interactive Brokers. But theyre data and support is terrible as you know. However, as an example is it possible to use CQG for data via AMP futures (they dont clear for this exchange but can provide data via CQG) and use Interactive Brokers for trade execution? Is there a better alternative that you can suggest?
[2020-07-23 20:36:56] |
This is possible, but it is an advanced configuration. You will find the information and instructions here: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Unfortunately, we do not offer the Korean Futures on our data feeds, so we do not know of any other solutions to what you propose. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
