Date/Time: Mon, 25 Nov 2024 09:39:00 +0000
[User Discussion] - Real time data update from broker
View Count: 1120
[2014-01-30 16:34:04] |
setapakforex - Posts: 10 |
Hi Support, Would sierra charts receiving real time data feed from brokers faster:- (a) if ping 1.5 ms from VPS location to broker, compare to (b) if ping 115 ms from location without VPS, OR (c) ping ms does not affect receiving data feed from brokers. (d) ping ms only affect execution order to broker. Please advice. Thank you. |
[2014-01-30 18:04:50] |
Please make your own determinations and conclusions about this.
