Date/Time: Sat, 08 Feb 2025 18:03:35 +0000
DOM: Fill Orders
View Count: 580
[2020-07-21 17:22:14] |
Brian E Mudrick - Posts: 3 |
Extremely Confused. Placing a Limit Order. Shows Filled. +/- P/L shows Green. Only able to Exit Position via Flatten. What is happening? |
[2020-07-21 20:00:54] |
You are currently receiving delayed data. You need to subscribe to the Denali Exchange Data Feed: Denali Exchange Data Feed Also update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-21 20:01:18
