Date/Time: Sat, 08 Feb 2025 18:10:34 +0000
Shares Outstanding Update Interval
View Count: 516
[2020-07-21 16:43:34] |
arkevo - Posts: 23 |
Hi All, Does anyone know how often does the "Shares Outstanding" variable in the "Quote Window" updates for the "Sierra Chart Exchange data feed" and "U.S. Equities (NYSE, NASDAQ, AMEX, BATS)"? Documentation says it depends on the data feed and I would like to see if someone can test or already knows before I make the purchase of Equities data feed. Thanks, Ivo |
[2020-07-21 19:53:19] |
That field would only be supported with IQ Feed. And we do not know how often it updates. But certainly the current value from IQ Feed is always displayed.
