Date/Time: Sat, 08 Feb 2025 18:16:57 +0000
Real time Data Subscription -- Plotting Delayed Data
View Count: 538
[2020-07-21 16:24:34] |
TapeReader - Posts: 89 |
Hi, I am subscribed to r\t data but my data feed seems to be lagging by 5 minutes...which is tripping up trades. I have had to go to Sim trading for now. Are there any known issues with the SC data feed? Thanks, Carl |
[2020-07-21 19:06:49] |
There are no issues with the Sierra Chart data feeds. What symbol is delayed? You may not have the corresponding exchange active for it. You may want to add the Data Delay field: Working With Charts: Region Data Line / Chart Header Can you please ensure that you have the Data Delay displayed in your Chart Header and then take a screen capture so we can see what that is showing for the delay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
