Date/Time: Mon, 25 Nov 2024 09:26:06 +0000
Single core & multiple instances of sierra
View Count: 1347
[2014-01-30 16:15:04]
100 - Posts: 147
Since Sierra runs without multicore processing, and tends to slow down as one adds more indicators / data / spreadsheets. Can I use more than one instance of Sierrachart on the same machine, and simply use one to feed / stream data for trading, and another for reading the data - post mortem?
[2014-01-30 16:16:31]
100 - Posts: 147
It makes a lot of sense to do this, since I can already run like 3 other platforms at once even while sierra lags 5 seconds behind at time*
[2014-01-30 18:02:37]
Yes you can do this. Refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/MultipleServices.html
For the lagging issue, refer to help topic 4:
http://www.sierrachart.com/index.php?l=doc/helpdetails4.html
In regards to lagging, this is not a Sierra Chart issue causing the lag. We see you are using Rithmic and there have been many reports of this lately. The issue has to do with available bandwidth or a server-side issue. Rithmic has contacted us about it and we are implementing some different connect points that should help.
