Date/Time: Mon, 25 Nov 2024 09:43:37 +0000
Numbers Bars Columns
View Count: 1107
[2014-01-30 16:07:36] |
Discount - Posts: 73 |
Can you tell me is there some setting to narrow the vertical data columns on the Sierra Numbers bars? Thanks
[2014-01-30 17:59:14] |
The only thing you can do is reduce the spacing between the chart bars as explained here: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-30 18:09:55] |
I understand that, but if I use this method to narrow the columns, the print for the data gets so small one can not read or monitor it. Can you tell me is there some setting to narrow the vertical data columns on the Sierra Numbers bars in a different method, as I do need to be able to read the data.
